  1. 379 ( VA3IUL)
  2. "" -
  3. DX-2000
  4. 80
  5. KB ""
  6. JUNGLE JOB,
  7. B
  8. YAGI 28
  9. 27
  10. YAGI 28
  11. - 27
  12. 160
  13. -
  14. 20
  15. " "
  16. -
  17. KB "" ( )
  18. KB "" ( )
  19. "ZYGI BEAM"
  20. ...
  21. MULTI BAND
  22. 7-
  23. "Windom"
  24. " "
  25. "sloper" ( )
  26. 160
  27. 160
  28. WINDOW
  29. 2- HB9CV
  30. (RX3AKT)
  31. GP-Plus
  32. "" 3,5
  33. "DELTA LOOP"
  34. UA1DJ
  35. ( 1)
  36. ( 2)
  37. J-
  38. GP 160
  39. 7
  40. 160
  41. (LOOP)
  42. -
  43. "" UB5UG
  44. 7
  45. KB "LAZY J"
  46. --
  47. KB
  48. GP 80
  49. 80 20
  50. GROUND PLANE 7 MGROUND PLANE 7 M
  51. WINDOM
  52. -
  53. KB
  54. QUAD
  55. 14/27/28
  56. 160
  57. 1:3
  58. Sigma-Yagi
  59. KB
  60. (HB9RU)
  61. 10 40
  62. "Lazy Delta" (" ")
  63. 136
  64. ""
  65. "" GP
  66. "" D2T
  67. INVERTED L 160
  68. 160-
  69. ...YAGI!
  70. Delta-Loop 10,1
  71. 21, 24, 27, 28, 30
  72. 2 . 7
  73. 5/8 l
  74. Hentenna
  75. VMA-9NP
  76. J l/2L160 L 80
  77. "BOX" HA 80
  78. DX-
  79. ""
  80. - !
  81. B
  82. 2- .
  83. RX3AKT (RX3AKT)
  84. J- DH1NAW
  85. 3,5 7
  86. -
  87. -
  88. ( ) WINDOM
  89. ""
  90. "" G4ZU
  91. VMA-10 NO PROBLEM
  92. VMA-10 NO PROBLEM (2)
  93. A compact 2 element beam for 10M
  94. UA1DZ
  95. Micro GP
  96. SP3PK (20, 15, 10)
  97. KT-34A KT-34XA (-12)
  98. YAGI 20 .
  99. 40 80
  100. (2,5 - 28 )
  101. " "
  102. .
  103. 40 20
  104. -
  105. +V
  106. 10-
  107. .
  108. DL1FDN mobile antenna
  109. : +
  110. (HB9ABX)
  111. The W5QJR Antenna Revisited (.)
  112. 3 Wires = The Whole World (.)
  113. 20, 15, 10-
  114. V-
  115. J-
  116. ( )
  117. VP2E
  118. ""
  119. ɻ ( )
  120. BEAM- 40
  121. , WINDOM ...
  122. (2)
  123. ________________________
  124. Moxon
  125. Double-D
  126. "" 80-20
  127. Moxon:
  128. N0KHQ
  129. Moxon
  130. Moxon
  131. 4:
  132. 6: (TheBruceArray):
  133. 2- Moxon
  134. Ш KB
  135. KB
  136. KB
  137. KB W3DZZ
  138. 28 144
  139. KB " "
  140. KB
  141. KB "LAZY J"
  142. .
  143. 1-
  144. "-"
  145. һ
  146. һ
  147. 160 30
  148. "" -
  149. 7 14
  150. һ
  151. ? 1,8...10,1 MHz
  152. ?
  153. SPIDER
  154. - l\2.
  155. KT-34A KT-34XA (-12)
  156. Delta, FO0AAA
  157. Ewe ?
  158. DELTA LOOP
  159. 80
  160. 3- Yagi
  161. 14 .
  162. 1.8
  163. 7
  164. , ,
  165. Halo 6-
  166. GP 14-28 z
  167. -
  168. 2 EL
  169. 3- band mobile antenna
  170. "Fuchs" - (RA3TOX)
  171. "Fuchs" 40 (RA3TOX)
  172. " Up and Outer"
  173. () .
  174. EFA " "
  175. " " . ( )
  176. ""
  177. R-QUAD
  178. 1428 M +7 +10
  179. RZ3TZZ.
  180. 2el Delta loop
  181. GP-Yagi 40
  182. J-Pole antennas for 2m-40m with Wireman-cable
  183. C-Pole
  184. MOXON
  185. 80
  186. Sloper
  187. 1428 MHz
  188. 160, 80, 40
  189. 7.0 30.0 MHz
  190. /UA3TW/
  191. ("")
  192. UA1DZ
  193. DELTA ROOST
  194. , ! 20
  195. -
  196. - KB
  197. , DELTA - ROOST
  198. SM0TDK
  199. Half Bobtail Antenna 50 MHz
  200. C-POLE PORTABLE ANTENNA FOR 20M
  201. DX-2000
  1. Yagi 2,4 Mavic Mini
  2. 70cm "Bazooka"
  3. Eggbeater II
  4. -
  5. -""
  6. -
  7. 435 ( )
  8. 145 (2 )
  9. HENTENNA 144 Mhz
  10. The DK7ZB Reflector Hentenna
  11. DDRR 2
  12. GL-Dipol - 137 MHz
  13. LFA
  14. UHF- 1296
  15. 145
  16. 144 MHz
  17. 1296 MHz
  18. HB9CV 2
  19. 2 70
  20. "Super Moxon" (144 MHz)
  21. ()
  22. 144
  23. 2
  24. 144
  25. -
  26. J-Yagi 144
  27. ""
  28. 144
  29. 6
  30. 144
  31. 144
  32. - UB5UG
  33. SN-258
  34. "Delta Loop" 144
  35. 435 145
  36. HB9RU 50 ...
  37. YAGI 144 .
  38. " 144
  39. - 144
  40. " " 144
  41. "Slim Jim" (G2BCX)
  42. 9- Swan- 144
  43. 144...146
  44. Bobtail-
  45. UT5VD 2-
  46. -
  47. 430-440 "Ш- "
  48. 4- 433-438
  49. 2
  50. DJ9BV 144
  51. 3- 433
  52. 430
  53. 145
  54. 144
  55. 3- 145
  56. " "
  57. 144
  58. ... (144 )
  59. YAGI 145,5
  60. -. (RV3TH)
  61. LPDV - 145/435
  62. " " 2.87, 3.62 4.12 . (RV3TH)
  63. 435
  64. 40 (2,4 )
  65. -40 (2,4 )
  66. 67 f/D=0,43 "" 40 (2,4 )
  67. My AO40 antenna projects
  68. 2,4 GHz
  69. 2,4 (RV3TH)
  70. 5/8 "-"
  71. 2
  72. Half-Square
  73. KB
  74. AO-10 Beam Antenna (.)
  75. AO27 70 .
  76. A Low Cost Phase 3D Antenna System: 2m & 70 cm Yagi Beams (.)
  77. 70 cm Quagi Antenna (.)
  78. 145
  79. 144 440
  80. F-22 RW
  81. 2- (145/433 ) 22 YAGI ()
  82. Fensterquad f?r 144 MHz
  83. -
  84. 2
  85. 2- -
  86. 1296
  87. GP 2 , 70 23
  88. DX 430
  89. Diamond F-23
  90. -
  91. RZ6FE
  92. 1227,6 GPS/GLONASS
  93. 145
  94. - J Super J 145 50
  95. . . (RA3TPQ)
  96. Antenna on the Cheap ( - 2400 MHz)
  97. 3- 145
  98. 3- 435
  99. Design your own J-Pole Antenna
  100. 435MHz 12-turn Helix Antenna
  101. Cheap Yagi Antennas for VHF/UHF
  102. The Original WINDOM Antenna, with complete construction details!
  103. MB
  104. -
  105. 5/8 - 2
  106. 144-146
  107. 144-146
  108. ()
  109. Dualband Log.Periodic Antenne fur 2m/70cm im Selbstbau
  110. 25/8 145
  111. 145 MHz, 7 dBd, ()
  112. Cross-Yagis for Terrestrial and Satellite Work
  113. Build a 2 Meter, 5/4 Wave Antenna
  114. Build A 9 dB, 70cm, Collinear Antenna From Coax
  115. ANTENNAS FOR LOW POWER APPLICATIONS ( -)
  116. Wlan antenna Waveguide type ( - 2,45 )
  117. EW8AU
  1. Mitsubishi Electric
  2. Ban(d)tenna
  3. DDRR.
  4. 432
  5. 144
  6. "-"
  7. 144-146
  8. "Isotron"
  9. PA0UNT PA1AMS
  10. "-"
  11. BIPLANE KC5MU
  12. EH-
  13. "" EH-
  14. ?
  15. The SteppIR antenna system
  16. - :
  17. All-band "Inverted L"
  18. A Small Loop Antenna for Forty Meters
  19. Build a 2 Meter DDRR for Mobile
  20. 70 .
  21. 40.
  22. G5IJ
  23. .html
  24. .html
  25. CAPACITIVE ANTENNAS FOR 40m, 30m AND 20m (EH )
  26. CAP-ANTENNA
  27. US Paten 2.485.457 - ANTENNA SYSTEM
  1. R3KN
  2. !
  3. Magnetic Loop
  4. 160
  5. UA6AGW 40 ( )
  6. UA6AGW ( )
  7. ..
  8. A Magnetic Loop Antenna
  9. Magnetic loop antenna =Mag-Loop, small transmitting loop
  10. Magnet-Loop 80/40m
  11. Magnetic Loop Antenna's
  12. Building a small transmitting loop(Magnetic Loop)
  13. PA3CQR Magnetic loop antenna page
  14. Using a Small Transmitting Loop
  15. What is a Small Transmitting Loop or MagneticLoop?
  16. A magnetic loop antenna for HF
  17. Die Helixantenne fur Kurzwellenbetrieb
  18. THE G3BGR MAGNETIC LOOP
  19. Magnetische Loop-Antennen
  20. Die Matchboxen fur Langdrahte, Helixantennen und symmetrische Antennen
  21. Die magnetische Antenne (small transmitting Loop)
  22. Sperrkreise aus Koaxialkabel, Baluns
  23. Langdraht-Antennen
  24. Verkurzte Vertikal-Antenne
  25. Experimente mit Isotronantennen- Nachbau fur das 80,40,30,20,17,15,12 und 10 Meter-Band
  26. VHF Antenna in a Lunchbox - The Magnetic Loop on Two Metres
  27. A Small Transmitting Loop Antenna for 14MHz and 21MHz
  28. Antenne cadre magnetique
  29. A ANTENA "MAGNETIC LOOP"
  30. Small Transmitting Loop Antennas
  31. Loop antenna
  32. A Backpacking Multi-band QRP 'Magnetic Loop' antenna
  33. 100
  34. RECEIVING LOOP AERIALS FOR 1.8 MHz
  35. The Magnetic Loop on Two Metres
  36. A Small Transmitting Loop Antenna for 14MHz and 21MHz
  37. A SMALL LOOP ANTENNA
  38. Magnetische Antennenkopplung
  39. ALO - Yet Another Loop - Die etwas andere Magnetic-Loop
  1. (DVB-T)
  2. ""
  3. 33-
  4. 1-12
  5. TV-
  6. -
  1. ?
  2. " ",
  3. ?
  4. :
  5. Inverted V -
  6. -
  7. .
  8. . .
  9. , "" ...
  10. Yagi,
  11. .
  12. ?
  13. ?
  14. 2 el
  15. ?
  16. -
  17. The BobTail Curtain
  1. L-
  2. -
  3. - -
  4. KB
  5. ,
  6. , -
  7. ()
  8. -
  9. ""
  10. - -
  11. -
  12. POCTO , ( 1)
  13. POCTO , ( 2)
  14. -
  15. BALUN BALUN?
  16. TVI 144
  17. Z-Match
  18. Z-Match Portable Antenna Tuner
  19. -: . -
  20. .
  21. TVI .
  22. FJ-259
  23. MFJ. 249/259. .
  24. 5/8l
  25. C
  26. TVI 144
  27. Z-Match
  28. Z-Match Portable Antenna Tuner
  29. "" , 1,8-50
  30. , -
  31. -
  32. 144
  33. 144/430
  34. .
  35. -
  36. RV4HV (1.6 ...200)
  37. - -
  38. 3-
  39. MFJ815B delux HF peak reading SWR/WATTMETER
  40. (RA3TOX)
  41. ( )
  42. -
  43. Was (noch) nicht im Antennenbuch steht. Das COAX-Radial
  44. 50
  45. -
  46. Projetos prticos de antenas e baluns - por Adalberto Marques
  47. WiFi (V)SWR Meter - - -
  48. ES4MF
  49. Homebrew A 4 To 1 Balun ( 4:1)
  50. . (UA3TCW)
  51. APAK-EL TM
  1. YAGI. (RV3TH-RA3TOX)
  2. - YAGI
  3. " "
  4. KB
  5. SPIDER
  6. ""
  7. ˸
  1. 2
  2. 430
  3. 430
  4. 2
  5. 2
  6. 144 BF998
  1. (On-line RA3TOX)
  2. -
  3. "MMANA"
  4. VHF\UHF\SHF
  5. ( )
  6. "APAK-EL"
  7. 137 ,
  8. RX
  9. VHF RX-TX
  10. YAGI.
  11. 2
  12. ()
  13. 6 / RN6AM
  14. ( 4 )
[ Home ]
